Doom port στο C64 με SuperCpu(20Mhz)
05/10/2014 23:38 #23264 από Nemo
Doom port στο C64 με SuperCpu(20Mhz) δημιουργήθηκε από Nemo
This is a (more or less) direct build of the original ID software source code release
with a hacked together tiny clib for the string/mem/math/etc functions it required.
While this DOOM port isn't meant to be taken seriously, it has proven quite
useful for testing and improving the MIPS recompiler as DOOM is a rather complex
and large application.
Some parts has been rewritten in assembler for better performance:
* Fixed point multiply/divide
* Chunky to bitmap conversion
* DrawColumn and DrawSpan
The original DOOM1.WAD shareware WAD has been embedded in doom.reu and may be extracted if desired:
dd skip=4128768 count=4196020 if=doom.reu of=DOOM1.WAD bs=1
Running in VICE:
xscpu64.exe -reu -reusize 16384 +reuimagerw -reuimage doom.reu -autostartprgmode 1 -autostart io.prg
Πρωιμη /πρωτη εκδοση του Doom port για C64 με SuperCPU
Τι εστι SuperCPU ??? ενα board με ενα 65c816 στα 20Mhz που συνδεονταν στο C64 μεσω του expansion port ,ενω συγχρονως δεχονταν μεχρι 16MB ram μνημη ) -το οποιο περιφερειακο btw μπορειτε να εξομοιωσετε μεσω Vice-.
Προελευση >>>scpu.amidog.se/doku.php?id=scpu:doom
D/load : Doom για Supercpu
Υ.Γ. just for the record
Ξερατε οτι στις αρχες του 2004 .....
CS-Doom64 challenge
Allan Bairstow of the Commodore Scene is holding a contest for the mainly European programmer of the C64. The goal is the well-known 3D shooter "Doom" as C64 version.
Interested parties are paid, although it really should be a work of passion. There is at least one SuperCPU needed. The current details: The goal is a "Doom" version that runs on the C64 and therefore is this call to all demo programmer to create something truly unique with their talent. For this is paid even money - even a lot! What to do? There was first a PayPal account created so that any programmer can be paid. There must be a functioning first level of the game, which should be the original as closely as possible, be sent to the organizers so that the ball gets rolling. .......
Οι ακόλουθοι χρήστες είπαν "Σε Ευχαριστώ": Fotis_KFOR, GeoAnas, chdlee, chriskgnr, stabill
06/10/2014 11:19 #23267 από Fotis_KFOR
Απαντήθηκε από Fotis_KFOR στο θέμα Doom port στο C64 με SuperCpu(20Mhz)
Φοβερό!!! :cheer:
Και αυτό το doom πανταχού παρόν μέχρι σήμερα... ;)
06/10/2014 11:50 #23269 από alex76gr
Απαντήθηκε από alex76gr στο θέμα Doom port στο C64 με SuperCpu(20Mhz)
Ε δεν είμαστε καλά!
Τι φτιάξαν οι άνθρωποι! :ohmy:
06/10/2014 17:26 #23277 από stabill
Απαντήθηκε από stabill στο θέμα Doom port στο C64 με SuperCpu(20Mhz)
...φημες αναφερουν οτι ετοιμαζεται το Crysis σε Spectrum!!!!! :P
(απιστευτο παντως... τελικα δεν υπαρχουν ορια...)
06/10/2014 17:55 - 06/10/2014 17:55 #23284 από glaros
Απαντήθηκε από glaros στο θέμα Doom port στο C64 με SuperCpu(20Mhz)
Χρόνος δημιουργίας σελίδας: 0.241 δευτερόλεπτα
