Ghost'n goblins Arcade((Remaster)-το κορυφαίο γίνεται ακόμα καλύτερο
21/06/2015 16:22 - 21/06/2015 16:27 #30383 από Nemo
This time we went all-out and improved the game as much as we could. Most of the code is either rewritten, bug fixed or improved in one way. Graphically and sound-wise the game is completely new, everything was redone and improved. Overall the game is around 4 times the size of the C64 original and is pretty close to the size of the Arcade.
List of major improvements:
- Two completely new levels added.Level 6 has an additional final room.
- Existing 4 levels are expanded to be twice the size of the original.
- All levels have completely new graphics and level designs applied.
- All levels have unique new tunes added which were newly composed.
- New Sound Effects added or changed.
- New sprite multiplexer coded, which will minimize glitches.
- Intro sequence added where Satan abducts the Princess.
- Game Map added, which shows your progress when you are killed or you reach incoming level.
- Game Complete animation added.
- Game Over sequence added.
- Two new Bosses added for levels 5 and 6. They are bigger than any existing enemies in the original game.
- Added a new Jumping Skeleton enemy in levels 5 and 6.
- Moving Clouds recoded so they can be used on level 5.
- Arthur now can turn around when he jumps and he can shoot backwards.
- Added an improved Title/Loading screen with new tune.
- Weapons are now improved and all of them now actually make sense.
- Enemies have improved AI - not perfect but much better than original.
- Levels 1-4 are done in 2 parts now, but transition between them is fully seamless.
- Flying Knights at level 2 can only be shot from behind as in Arcade.
- Zombies first dig out some dirt so you can spot them before they kill you.
- Collision detection is drastically improved - you won't get killed when a bullet flies over your head anymore.
- Dragon Boss covers more of the screen area now and you need to shoot his head three times, and he won't shoot so many bullets anymore.
- House Ogres are easier to kill now.
- 'Sparkles' are now visible when you hit an enemy.
- Weapons that are dropped depend on the level you are playing, so you cannot get the shield in the beginning.
- Pause Game and Quit Game added, which can be activated by Run/Stop key.
- Arthur can jump over obstacles now even if he touches them. In the original he only jumped up.
- Time limit is now different for each level.
Ενα ηδη κορυφαιο (8bit port ) γινεται ακομα καλυτερο ,στα βηματα του Commando Arcade SE ,αφου περα της ομαδος που ανελαβε το remastering και οι 2 συγκεκριμμενοι τιτλοι ηταν "θυματα" της επιμονης/"εμπορικης" επιλογης της Elite να ειναι οπωσδηπωτε single load .
D/load >>> csdb.dk/release/download.php?id=172738
Οι ακόλουθοι χρήστες είπαν "Σε Ευχαριστώ": Fotis_KFOR, GeoAnas, chdlee, amiga500fan
21/06/2015 18:18 #30391 από GeoAnas
Θαυμάσιο !!!
21/06/2015 19:31 #30396 από amiga500fan
Παιχνιδάρααααααααααααααααααα!!!! :thanx:
22/06/2015 10:12 #30411 από chdlee
Ευχαριστούμε πολύ φίλε Nemo!
Μακάρι να υπήρχε και μια έκδοση tap, ώστε να έιχα τη δυνατότητα να τη δοκιμάσω και στο δικό μου C64!
:huh:
  • mastersly
  • Το Άβαταρ του/της mastersly
  • Commodore computers fanatic
22/06/2015 11:53 #30416 από mastersly
Παίδες το δοκίμασα στον emulator προς το παρόν . Πραγματικά πολύ καλή δουλειά . Μπράβο τους . Mακάρι να βγαίνουν καινούργιες και πιο βελτιωμένες εκδόσεις για όλα αυτά τα classics . :clap1:
22/06/2015 13:40 #30418 από VincentGR
chdlee έγραψε: Ευχαριστούμε πολύ φίλε Nemo!
:huh:
Τρεις μέρες το παλεύω, τελικά το έκανα αλλά φάγαμε κρυάδα.
Μετά από λίγο ψάχνει disc loader...
Πέρα από τις δυνάμεις μου.
Οι ακόλουθοι χρήστες είπαν "Σε Ευχαριστώ": Nemo
Χρόνος δημιουργίας σελίδας: 0.243 δευτερόλεπτα
