Η Amiga στη NASA.
  • Το Άβαταρ του/της VincentGR Συντάκτης θέματος
24/04/2014 14:59 #19690 από VincentGR
Η Amiga στη NASA. δημιουργήθηκε από VincentGR
Ένα ενδιαφέρον video για τη χρήση της Amiga στη NASA.
Οι ακόλουθοι χρήστες είπαν "Σε Ευχαριστώ": Fotis_KFOR, GeoAnas, spyros.s, Nemo, vovolas
  • Το Άβαταρ του/της Nemo
25/04/2014 01:27 #19697 από Nemo
Απαντήθηκε από Nemo στο θέμα Η Amiga στη NASA.
In an interview dating back to 1999, Gary Jones, principal systems engineer for NASA’s software systems at Cape Canaveral puts the quality of the Amiga this way:
“It just turned out that it was a good machine (the Amiga). The things that make a machine good for playing games also tend to make it good for processing and displaying data, because you’ve got some of the same problems. You need a very efficient, very fast operating system, and the Amiga has that and very little overhead too. That’s what makes it nice; we don’t load down the system running the overhead; we can just process the data.”
From a price perspective, he adds that apparently NASA couldn’t believe that a system as cheap as the Amiga could be so powerful and reliable:
“If it’s not a PC, NASA gives us a lot of grief when we try to buy anything to go with the Amiga. They want us to buy PCs and run Windows 95 and NT. We keep trying to tell them it’s not fast enough so they tell us to buy DEC Alphas. We tell them it’s too expensive. They don’t like the Amiga; it doesn’t cost enough.“
And the Amiga, above all, was a very reliable system, or how else could you trust several parts of the operations of spacecraft like the Atlas-Centaurs, Delta II and Delta III, a couple different models of the Titan and even the Space Shuttle!
Credit also goes to the people at Commodore, who were, as NASA employees put it, amazing in the level of co-operation (and one of the reasons they didn’t go the Mac route):
“And Commodore was easy to work with back then. When we asked for documentation, they sent us a stack of documentation about four feet high. They were willing to tell us everything about their machine. Since we had to design some custom hardware to go inside, it really helped to know exactly how everything worked.”
The Amiga line at NASA lasted until 2004 and eventually decommissioned in 2006, another testament to the great products Commodore gave us.
Report : Amiga at NASA
(Article written by Bob Castro - March 1999)
>>> obligement.free.fr/articles_traduction/amiganasa_en.php
Ετσι για να ειναι -νομιζω- και ποιο ολοκληρωμενο το thread
Οι ακόλουθοι χρήστες είπαν "Σε Ευχαριστώ": Fotis_KFOR, GeoAnas, VincentGR, vovolas
  • DAT-Alex
  • Το Άβαταρ του/της DAT-Alex
  • Project MK-14 συνεχεια...
25/04/2014 10:33 #19701 από DAT-Alex
Απαντήθηκε από DAT-Alex στο θέμα Η Amiga στη NASA.
Πω Πω! φανταστικές πληροφορίες.... Μπράβο που τις μοιραστήκατε μαζί μας .... :thanx:
web: www.retroclub.gr
25/04/2014 17:17 #19706 από spyros.s
Απαντήθηκε από spyros.s στο θέμα Η Amiga στη NASA.
φανταστείτε σε τι κόσμο ζούμε...κάποιοι κάποτε συνέκριναν αυτό το υπερμηχάνημα με τα μηχανακια της ατάρι και τις κονσόλες των σεγκονιτνεντο...
ΑΜΑΡΤΙΑ ΤΕΚΝΑ ΜΟΥ! :P
25/04/2014 17:44 #19707 από Fotis_KFOR
Απαντήθηκε από Fotis_KFOR στο θέμα Η Amiga στη NASA.
Όντως Respect :cheer:
Πρώτη φορά το είδα το βιντεάκι, ευχαριστούμε για την ενημέρωση :cheer:
(Βλέπω οι Atarάδες να ψάχνουν για κάποιο ανάλογο βίντεο με Atari να παρουσιάσουν) ;)
26/04/2014 02:07 #19710 από VincentGR
Απαντήθηκε από VincentGR στο θέμα Η Amiga στη NASA.
Fotis_KFOR έγραψε: (Βλέπω οι Atarάδες να ψάχνουν για κάποιο ανάλογο βίντεο με Atari να παρουσιάσουν) ;)
Μη λες τέτοια και σαμποτάρουν πάλι τα ταμπελάκια...
26/04/2014 04:53 - 26/04/2014 04:56 #19711 από Nemo
Λαβαινοντας υποψη ,οτι στο 3.24 του συγκεκριμμενου video,video που αποτελεσε την αφετηρια του thread και βαση για οσα σχολια ακολουθησαν, ανεφερεται οτι πρωτη τους επιλογη ηταν τα Macintosh ,αλλα τους αποθαρρυνε το γεγονος , οτι ηταν closed system και η ενγενει απροθυμια της Apple να τους δωθει το απαραιτητo Documentation/info για να το φερουν στα μετρα τους e.t.c. ,μαζι με το κομμενο budget τους οδηγησε στην επιλογη της Amiga .
Δεν νομιζετε επομενως κυριοι συν-Commodore-αδες ,οτι αυτα καθ'αυτα τα σχολια ειναι κομματακι υπερβολικα?
26/04/2014 09:30 - 26/04/2014 09:31 #19713 από spyros.s
αν για σένα το γεγονός ότι η αμίγκα κατάφερε να προσφέρει περισσότερα, σε φθηνότερη τιμή και μάλιστα αξιόπιστα σε σχέση με το μηλοπροϊόν είναι κάτι αρνητικό, τότε, νομίζω ότι λειτουργείς στην βάση του "όσα δεν φτάνει η αλεπού τα κάνει κρεμαστάρια" :P
Τα μακιντος ήταν ακριβότερα και δεν άξιζε -όπως αποδείχτηκε περίτρανα- η αγορά τους σε σχέση με την αμίγκα! Αν ήξεραν από promotion και marketing στην commodore θα είχαν γίνει τουλάχιστον ότι έγινε η apple στα '00ς! Αλλά που μυαλό στους αυτοκαταστροφικούς...
26/04/2014 12:01 #19722 από VincentGR
Nemo έγραψε: Λαβαινοντας υποψη ,οτι στο 3.24 του συγκεκριμμενου video,video που αποτελεσε την αφετηρια του thread και βαση για οσα σχολια ακολουθησαν, ανεφερεται οτι πρωτη τους επιλογη ηταν τα Macintosh ,αλλα τους αποθαρρυνε το γεγονος , οτι ηταν closed system και η ενγενει απροθυμια της Apple να τους δωθει το απαραιτητo Documentation/info για να το φερουν στα μετρα τους e.t.c. ,μαζι με το κομμενο budget τους οδηγησε στην επιλογη της Amiga .
Ο Mac ήταν αλλά στη πορεία ανακάλυψαν πως τελικά η Amiga ήταν αυτό που ήθελαν.
Ο πρώτος λόγος όπως είπες και εσύ ήταν η πολιτική -αποφασίζουμε και διατάζουμε- του μήλου.
Ο δεύτερος είναι το comment του στο έκτο λεπτό. Αν και έχω ασχοληθεί ελάχιστα με Mac, δε νομίζω να μπορεί τα τρέξει "καθαρά" ο τότε Mac πάνω από 2 προγράμματα όπως η Amiga.
Έχω τρέξει Mac emul στην Amiga και στο ίδιο config των μηχανημάτων η Amiga ξεπερνάει τον αντίστοιχο Mac στα benchmarks.
4:45 very efficient, very fast.
6:09 we can support more than one in the same machine
Κουβέντα να κάνουμε έτσι :tease: φιλικά τα λέω.
26/04/2014 16:57 - 26/04/2014 17:29 #19740 από Nemo
"Πατουλιδ-ιζετε" ασυστολα κυριοι.
Κανενας δεν αμφισβητησε το κατα ποσο αριστη ή οχι ηταν η επιλογη των Amig-ων.
Και μονο το γεγονος οτι μεχρι το 2004!!!! παρεμεναν μαχιμες ,παρολη την τραγικη πορεια της <<μαμας εταιρειας>> και των τρελων τεχνολογικων εξελιξεων εντωμεταξυ ,αποδυκνυει περιτρανα και χωρις να χρειαζεται να πεις τιποτα παραπανω για την ποιοτητα και την σχεδιαση του hardware αλλα και του software που τις συνοδευε .
Παρολα αυτα επρεπε να "σκονταψει" ο Macintosh/Apple , για να γινει προφανες .
:devil:
26/04/2014 19:24 #19741 από spyros.s
Αν ίσχυε αυτό που γράφεις ουδέποτε θα είχε καθιερωθεί ο οποιοσδήποτε υπολογιστής πέραν του πρώτου!
Θα είχαμε όλοι c64 αφού δούλευε καλά...δεν θα δοκιμάζαμε κάτι άλλο για να δούμε αν είναι καλύτερο!
Έτσι έκανε και η ΝΑΣΑ. Στα χαρτιά οι προδιαγραφές ήταν τέτοιες που να βόλευε ο μακ!
Οι συγκυρίες τους οδήγησαν σε εναλλακτικές επιλογές που τελικά βγήκαν καλύτερες! Αυτό κάνει την επιλογή της αμίγκα στη νάσα τυχαία; Εκτός και αν πιστεύεις ότι δεν έψαξαν κάτι άλλο πριν καταλήξουν εκεί...
26/04/2014 21:01 #19746 από VincentGR
Nemo έγραψε: "Πατουλιδ-ιζετε" ασυστολα κυριοι.
χαχαχα καλό :laugh4:
Κοίτα, υπάρχουν ακόμα αλλά είναι μυστικό :yes:
09/05/2014 22:46 #19995 από vovolas
Απαντήθηκε από vovolas στο θέμα Η Amiga στη NASA.
Πολύ σημαντική πληροφορία φίλε VincentGR τελικά αιωρείται ένα τεράστιο πέπλο τελειότητας γύρω απο την amiga εγώ αυτό έχω καταλάβει,και με αυτά και αυτά αισθάνομαι περήφανος που την έχω ακόμα στην αγκαλιά μου.
Χρόνος δημιουργίας σελίδας: 0.316 δευτερόλεπτα
