JavaCPC Desktop
  • Devilmarkus
  • Το Άβαταρ του/της Devilmarkus Συντάκτης θέματος
08/05/2013 16:52 #10185 από Devilmarkus
JavaCPC Desktop δημιουργήθηκε από Devilmarkus
Hello people,
perhaps you know, that I am developing the JavaCPC Desktop Emulator.
So my news here:
JavaCPC Desktop 2.0a is out!
Because of lacking time and motivation, I decided to roll-out version 2.0a.
What is new?
- Built-in "direct font editor" -> you now can edit the system rom's font. (It also opens a user defined font)
You can also store modified fonts as headerless binary or into a new lower-OS-ROM file.
Press ALT + F11 to open it. (Or check in menu -> Edit -> Open Font Editor)
- A wallpaper is set by default now. 4 wallpapers are available now. (1920x1080 pixels) You of course can also set your own wallpaper.
- The menubar now also shows up, when desktop is "Expanded"
What has changed?
- Several minor bugfixes.
- Bugfixes in the internal paint application
- Rewritten code to posterize images (Turn your favourite photo/image into a CPC-pixelized image keeping the original proportions)
- Internal java console is now turned off by default. (You can still enable/disable it in the preferences)
You can run an update or download 3 different files:
- JavaCPC_Desktop_2.0a.zip -> Complete emulator in a ZIP archive
- JavaCPC_2.0a_Setup.zip -> Complete emulator as a setup file
- JavaCPC_Desktop_Online_Setup.zip -> Only the online installer, put it somewhere you want to install JavaCPC inside, and launch it.
For those of you, who run the update:
- When the update runs first time, the updater self-closes.
- Launch JavaCPC.exe again then, and a 2nd update starts, which updates the Update.jar itself and also the last required files.
This happens, because in this release, the updater changed, too.
You can find the files here:
cpc-live.com/data/index.php
Have fun!
P.S.: feel free to ask questions about it, or ideas for new features, etc...
Υπάρχουν 10 είδη ανθρώπων: αυτοί που μπορούν να κατανοήσουν το δυαδικό και αυτοί που δε μπορούν...
There are 10 sorts of humans: Those, who understand binary, and those, who don't
Οι ακόλουθοι χρήστες είπαν "Σε Ευχαριστώ": GeoAnas, chdlee, Nemo, amiga500fan, dukepapas, mastersly, DUser1
08/05/2013 19:23 #10194 από Fotis_KFOR
Απαντήθηκε από Fotis_KFOR στο θέμα Απ: JavaCPC Desktop
Hi again DevilMarkus,
thanks for letting us know. :)
09/04/2015 09:03 #28386 από Fotis_KFOR
Προς ενημέρωση, ο DevilMarkus έχει ανανεώσει το JavaCPC Desktop στην έκδοση 2.9j.
Μπορείτε να τη δείτε εδώ καθώς και κάποια changelogs :
cpc-live.com/download.php?view.2
09/04/2015 11:39 #28391 από amiga500fan
Απαντήθηκε από amiga500fan στο θέμα JavaCPC Desktop
Kαλά, ο τύπος έχει κάνει φοβερή δουλειά!!!!Μπράβο του!!!! :clap2: :clap2:
Χρόνος δημιουργίας σελίδας: 0.393 δευτερόλεπτα
