- us robotics usr9108
us robotics usr9108
- Phobos
- Ληφθείσες Ευχαριστίες 9
29/09/2013 23:19 #13464
από Phobos
us robotics usr9108 δημιουργήθηκε από Phobos
πωλειται η ανταλλασετε με PSP κουτατο οποιο μοντελο να ναι
τιμη 50 ευρω
χαρακτηριστικα
Product Information
Surf the Internet from any corner of your home with the USRobotics USR9108 4-Port router. With a data transfer rate of 125 Mbps, this USRobotics wireless router provides high-speed Internet access. Moreover, with IPSec capabilities, the USRobotics USR9108 router allows you to share or transfer data between networks without any loss. Using the built-in 128-bit WEP encryption, this USRobotics wireless router ensures secure transmission of data from one network to another. Featuring a firewall protection, this 4-port router provides security against a wide range of hacker attacks. What’s more, with VPN pass-through, this router allows users to access the network from remote locations.
Product Identifiers
Brand USRobotics
Model USR9108
MPN USR9108
UPC 738168037414, 738168039296
Key Features
Wireless Technology Wireless G
Wireless Speed 125 Mbps
Port Speed 10/100
DLNA Certified No
USB for File Sharing No
Built in Modem Yes
Connectivity Wired & Wireless
Router Functionalities DSL Modem, Firewall, Print Server, VPN Pass-Thru, Wireless Access Point
Port Qty 4-port
Antenna Type Detachable Antenna x 2
Interfaces
LAN Interfaces 10/100 Base-T
WAN Interfaces 1 x RJ-11 for DSL
Additional Interfaces 1 x USB
Standards
WLAN Standards IEEE 802.11b, IEEE 802.11g/b
DSL Standards ADSL Full Rate (G.DMT ITU G.992.1), ADSL Lite (G.Lite ITU G.992.2)
Protocols
General Protocols IP, PPPoA, PPPoE, TCP
Remote Management Protocols HTTP
VPN Protocols IPSec Pass-Thru, L2TP Pass-Thru, PPTP Pass-Thru
Firewall / VPN
Firewall Features IP Filtering, Stateful Packet Inspection (SPI)
Wireless
802.11b Data Rates 11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps
802.11g Data Rates 125 Mbps, 54 Mbps, 48 Mbps, 36 Mbps, 24 Mbps, 28 Mbps, 12 Mbps, 9 Mbps, 6 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps
Max Transfer Rate 8 Mbps
Nonstandard Data Rate 125 Mbps (802.11g)
Upstream Speed 1 Mbps
Modulation 16QAM, 64QAM, BPSK, CCK, DBPSK, DQPSK, DSSS, OFDM, QPSK
Security 802.1x, AES, TKIP, WEP, WPA
WEP Encryption Length 128 bit, 40 bit (=64 bit)
Dimensions
Height 1.6 in.
Width 9.2 in.
Depth 5.5 in.
Weight 1 lb
τιμη 50 ευρω
χαρακτηριστικα
Product Information
Product Identifiers
Brand USRobotics
Model USR9108
MPN USR9108
Key Features
Port Speed 10/100
DLNA Certified No
Built in Modem Yes
Port Qty 4-port
Interfaces
Standards
Protocols
Firewall / VPN
Wireless
Dimensions
Height 1.6 in.
Width 9.2 in.
Depth 5.5 in.
Weight 1 lb
Χρόνος δημιουργίας σελίδας: 0.215 δευτερόλεπτα
