VecFever for Vectrex by Thomas Sontowski
19/11/2016 07:58 #37923 από GeoAnas
VecFever for Vectrex by Thomas Sontowski δημιουργήθηκε από GeoAnas
Και να που ήρθε το πλήρωμα του χρόνου και μόλις τώρα ο Thomas μου έδωσε το πράσινο φως να ρίξω φως στο μυστικό project που δούλευε πολύ καιρό τώρα!!!
Πρόκειται για μια cartridge που θα απογειώσει ότι ξέραμε μέχρι τώρα για την μαγική αυτή κονσόλα...
Για να μην μακρηγορώ, ορίστε μια πρώτη λίστα των χαρακτηριστικών του VecFever:
VecFever specifications:
- Ιncorporates 16MB memory that acts as a normal USB disk when plugged into a computer
- Compressed binary support to reduce filesize
- Allows convenient access of files using a built-in file browser with full ASCII fonts, long filename support, automatic sorting of filenames etc.
- No patches needed - all Vectrex cartridges work verbatim
- Switching between menu and cartridge always possible via reset button
- Includes a full version of 'Robot Arena', including storage of hiscore and options
- Multiple extra features for VecFever-aware cartridges, e.g. permanent storage of up to 4K per cartridge, global calibration parameters for faster drawing capabilities and a multi-bank extension allowing 4095 32k-banks per cartridge.
- Customizable: the entire menu can be loaded from disk allowing updating or changing the capabilities and look of the VecFever. It comes with three versions to choose from: the in-built gamer menu, an 'expert' menu with a lot more options and a special 'developer' menu for even more options geared towards developers including a ramdisk mode for developers to allow uploading and testing of up to 64k binaries immediately on a Vectrex via USB
+ Hiscore option
The VecFever allows via one global option to convert known, 'normal' cartridges into VecFever cartridges that include full hiscore tables with eight entries plus the entry and display capability in-game. The goal always was to convert the games in a way that during normal gameplay not a single cycle was changed, only after gameplay the 'game over' part was taken over and a hiscore entry/display was added so that the scores are comparable to 'normal' carts.
The menu also allows displaying/managing and customizing these hiscore tables - and there is not only one hiscore table per game, there are named hiscore tables for each gamemode and 1P/2P games, too, if wanted.
Right now this option converts about 30+ games, most vintage ones and quite a few homebrews....
Είμαι πάρα πολύ ευτυχής γιατί παρακολούθησα την πορεία του VecFever από πολύ κοντά και φυσικά θα είμαι μεταξύ των testers που θα παραλάβουμε τα πρώτα κομμάτια για ενδελεχή έλεγχο στις κονσόλες μας.
Όπως καταλαβαίνετε, δεν πρόκειται για μια απλή flash cart. Υπάρχει build in cpu . Υπάρχει τεράστιο απόθεμα 16 MB RAM . Υπάρχει μια πλήρη βελτιστοποιημένη τεχνική bank switching που θα μας κάνει να παραμιλάμε γιατί θα δούμε "cartridge" files μεγέθους 1024 KB!!!!....Υπάρχει πρόβλεψη για πολλά καλούδια που θα έρχονται σιγά-σιγά και θα προστίθενται στις απεριόριστες δυνατότητες του Vecfever, που από ότι γνωρίζω θα προσδίδουν χαρακτήρα "λειτουργικού συστήματος"...
Όπως θα δείτε στο video, μιλάμε για ενσωματωμένο jukebox, μιλάμε για ένα βασικό txt viewer, μιλάμε για video format που θα υποστηρίζει το VecFever και θα τρέχει στο Vectrex, μιλάμε....μιλάμε....μιλάμε για τα επτά θαύματα του κόσμου μέσα στο Vectrex !
Ακολουθούν λίγες ακόμη screens...
....Η διάθεση του θα αρχίσει γύρω στα Χριστούγεννα...
Οι ακόλουθοι χρήστες είπαν "Σε Ευχαριστώ": Fotis_KFOR, nkary, chdlee, glaros, sly*m
  • sly*m
  • Το Άβαταρ του/της sly*m
19/11/2016 11:24 #37925 από sly*m
Απαντήθηκε από sly*m στο θέμα VecFever for Vectrex by Thomas Sontowski
Πάρα πολύ καλο!!!!! Μπράβο παιδιά!!!
19/11/2016 12:57 #37927 από glaros
Απαντήθηκε από glaros στο θέμα VecFever for Vectrex by Thomas Sontowski
1 pc for me !
19/11/2016 14:54 #37928 από Fotis_KFOR
Απαντήθηκε από Fotis_KFOR στο θέμα VecFever for Vectrex by Thomas Sontowski
Ο Thomas όντως δημιούργησε ένα πολύ ωραίο και δυνατό project, πρέπει να έπεσε πολύ δουλειά και πολύ μεράκι για να γίνουν όλα αυτά που διαβάζουμε!
Μπράβο του, όπως και σε εσένα Γιώργο που με τους υπόλοιπους beta testers θα συνεισφέρετε με τον τρόπο σας στο project αυτό. :cheer:
20/11/2016 09:28 #37949 από chdlee
Απαντήθηκε από chdlee στο θέμα VecFever for Vectrex by Thomas Sontowski
Μπράβο Γιώργο στον Thomas Sontowski και σε σας τους υπόλοιπους που τον υποστηρίζετε για να γίνει αυτό το έργο!
Περιμένουμε και άλλες εικόνες για το τι μπορεί να κάνει το VecFever στο Vectrex!
:cheer:
:friends:
20/11/2016 13:21 #37951 από GeoAnas
Απαντήθηκε από GeoAnas στο θέμα VecFever for Vectrex by Thomas Sontowski
Ευχαριστώ βρε παιδιά! Αυτό το project το είχα πολύ "μεράκι" ...Anyway, να δούμε πως θα πάνε τα πρώτα κομμάτια που θα παραλάβουμε και θα σας κρατάω ενήμερους !
Οι ακόλουθοι χρήστες είπαν "Σε Ευχαριστώ": Fotis_KFOR, chdlee, sly*m
Χρόνος δημιουργίας σελίδας: 0.290 δευτερόλεπτα
