Διάφορες εργασίες / αλλαγές στο site
11/04/2019 01:40 #44548 από Fotis_KFOR
Απαντήθηκε από Fotis_KFOR στο θέμα Διάφορες εργασίες / αλλαγές στο site
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.9.5).
Joomla 3.9.5 is now available. This is a security fix release for the 3.x series of Joomla which addresses three security vulnerabilities and contains over 20 bug fixes and improvements.
What's in 3.9.5?
Joomla 3.9.5 includes three security vulnerabilities fixes and several bugs and improvements, including:
Security Issues Fixed
- Low Priority - Core - Directory Traversal in com_media (affecting Joomla 1.5.0 through 3.9.4)
- High Priority - Core - Helpsites refresh endpoint callable for unauthenticated users (affecting Joomla 3.2.0 through 3.9.4)
- Moderate Priority - Core - Object.prototype pollution in JQuery $.extend (affecting Joomla 3.0.0 through 3.9.4)
Bug fixes and Improvements
- User Password: Add minimum lowercase rule for password validation
- Associations tab: Fix wrong behaviour of Indonesian language
- Debug language: Fix User Actions Log Manager
- New installation language: Kazakh
- Google Authenticator plugin (2FA): QR-code generator implemented
21/04/2019 23:35 #44599 από Fotis_KFOR
Αναβαθμίστηκε το φόρουμ στην νεότερη έκδοσή του (Kunena 5.1.11).
The Kunena team is proud to announce the arrival of Kunena 5.1.11 [K5.1.11] which is now available for download as a native Joomla extension for Joomla 3.9.x. This version addresses most of the issues that were discovered in K 5.1 and issues discovered during the development stages of K 5.1.11.
The key distinctions of K 5.1.11 are:
- Fix for lock / sticky / delete changing original Topic Label text
- Issue with report to stopforumspam which waiting a second parameter
- Deleted posts view don't have option to move items
- Cleanup IP input don't have enough space
- Allow one message per page
- Parsing error in language file com_kunena.templates.ini
- Avoid duplicate meta description on replies
- Some backend language strings are missing
- Rating stars are not showing
- Marks some methods as deprecated in KunenaImage class
- instance of Joomla\CMS\Menu\SiteMenu, instance of JMenuSite given
- fix for error handling saveUser function
- Add more id's on index
- preg_replace_callback(): Compilation failed: invalid range in character class
- Update Fontawesome
24/04/2019 12:39 #44607 από Fotis_KFOR
Πριν 3 μέρες αναβαθμίστηκε το φόρουμ και στα καπάκια βγήκε νέα έκδοση / ενημέρωση λόγω κάποιου θέματος ασφαλείας που ανακαλύφθηκε στην προηγούμενη έκδοση. Έτσι, για να έχουμε δουλειά μέσα στη Μεγάλη Εβδομάδα :shake: :P
Αναβαθμίστηκε το φόρουμ στην νεότερη έκδοσή του (Kunena 5.1.12).
The Kunena team is proud to announce the arrival of Kunena 5.1.12 [K5.1.12] which is now available for download as a native Joomla extension for Joomla 3.9.x. This version addresses most of the issues that were discovered in K 5.1 and issues discovered during the development stages of K 5.1.12. This update fixed 1 security issue.
We have Released K5.1.12 because of a 1 High Security issue
We have Released K5.1.12.1 because the missing Subject on tabs.
The key distinctions of K 5.1.12 are:
- 1 Security fix - High
08/05/2019 21:53 - 08/05/2019 21:54 #44693 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.9.6).
Joomla 3.9.6 is now available. This is a security fix release for the 3.x series of Joomla which addresses two security vulnerabilities and contains over 25 bug fixes and improvements.
What's in 3.9.6?
Joomla 3.9.6 includes two security vulnerability fixes and several bugs and improvements, including :
- Low Priority - Core - XSS in com_users ACL debug views (affecting Joomla 1.7.0 through 3.9.5)
- Low Priority - Core - Core - By-passing protection of Phar Stream Wrapper Interceptor (affecting Joomla 3.9.3 through 3.9.5)
- Media Manager: Fix logic in file upload check introduced in 3.9.5
- Edge Chromium support added
- User Notes: Fix date format
- Frontend editing: article category editable by Publishers and up
- Cache: Cache folder automatically created if it doesn’t exist
- PostgreSQL database improvements
14/06/2019 00:27 #44887 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.9.7 και Joomla! 3.9.8 λόγω άμεσου νέου update).
Joomla 3.9.7 is now available. This is a security fix release for the 3.x series of Joomla which addresses three security vulnerabilities and contains over 40 bug fixes and improvements.
What's in 3.9.7?
Joomla 3.9.7 includes three security vulnerability fixes and several bugs and improvements, including:
Low Priority - Core - CSV injection in com_actionlogs
Low Priority - Core - XSS in subform field
Low Priority - Core - ACL hardening of com_joomlaupdate
Batch system: Copy permissions of modules and categories
Progessive cache improvements
Fix to avoid duplicated custom fields in com_content
RTL improvements
Removal of the unofficial French Help Server
TinyMCE improvements
RSS: Fix to display the right category
Media Manager: Fix directory traversal for symlinked folders
User registration: Correct http schema used
Joomla 3.9.8 is now available. This is a bug fix release for the 3.x series of Joomla which addresses one bug introduced into 3.9.7 which affects web sites using the French Help Server.
What's in 3.9.8?
Joomla 3.9.8 is fixing one bug introduced into Joomla 3.9.7, due to the removal of the French Help Server.
12/07/2019 13:00 #45085 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.9.9 και Joomla! 3.9.10 λόγω άμεσου νέου update).
Joomla 3.9.9 is now available. This is a security fix release for the 3.x series of Joomla which addresses one security vulnerability and contains over 30 bug fixes and improvements.
What's in 3.9.9?
Joomla 3.9.9 includes one security vulnerability fix and several bugs and improvements, including:
Low Priority - Core - Filter attribute in subform fields allows remote code execution
Repeatable Custom Fields: fix to keep HTML tags #25189
Media Manager: Modal layout improved #22475
Voting: Cache cleaned after voting #25201
Article ordering: Items grouped by category first #25295
Batch system: Improvements for Contact and Newsfeed
Joomla 3.9.10 is now available. This is a bug fix release for the 3.x series of Joomla which addresses one bug introduced into 3.9.9, affecting template styles of multilingual web sites.
What's in 3.9.10?
Joomla 3.9.10 is fixing one bug introduced into Joomla 3.9.9 which affects the template styles of multilingual sites and results in lost data.
24/07/2019 17:22 - 24/07/2019 17:23 #45132 από Fotis_KFOR
Αναβαθμίστηκε το φόρουμ στην νεότερη έκδοσή του (Kunena 5.1.13), καθώς και κάποια προγράμματα του site.
The Kunena team is proud to announce the arrival of Kunena 5.1.13 [K5.1.13] which is now available for download as a native Joomla extension for Joomla 3.9.x. This version addresses most of the issues that were discovered in K 5.1 and issues discovered during the development stages of K 5.1.13
The key distinctions of K 5.1.13 are:
- Some datepickers are not translated
- Add Class to category header
- Fix missing follow on Profile page
- PHP 5.6 Compatibility issues
- Malformed page title when insert ampersand
- SEO: Duplicate title and description in user list
- Jomsocial plugin add option stream limit
- Editor: User can't remove attachments in the editor
- Different birth date values in the profile and database
- Quick select has always first category selected
- Backend User edit: Two options can not be saved
- fix missing title subject on reply
- Update languages
16/08/2019 17:32 - 31/10/2019 20:16 #45192 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.9.11).
Joomla 3.9.11 is now available. This is a security fix release for the 3.x series of Joomla which addresses one security vulnerability and contains over 25 bug fixes and improvements.
What's in 3.9.11?
Joomla 3.9.11 includes one security vulnerability fix and several bugs and improvements, including :
Security Issues Fixed :
- Low Priority - Core - Hardening com_contact contact form
Bug fixes and Improvements :
- Custom Fields: Fix language strings/unknown columns/sorting
- Creating categories on the fly with numbers
- Fix database schema checker for MySQL 8
- Tree sorting in templates file tree
- Improved PHP 7.4 compatibility
Αναβαθμίστηκε το φόρουμ στην νεότερη έκδοσή του (Kunena 5.1.14).
The Kunena team is proud to announce the arrival of Kunena 5.1.14 [K5.1.14] which is now available for download as a native Joomla extension for Joomla 3.9.x. This version addresses most of the issues that were discovered in K 5.1 and issues discovered during the development stages of K 5.1.14. This update fixed 1 security issue.
We have Released K5.1.14 because of a 1 High Security issue
1 New feature to turn off "Re:" on subject names.
The key distinctions of K 5.1.14 are:
- Fix canonical in search
- Add ID to category counter
- Fix errors on DiscussionForumPosting
- Add option to disable Re on subject
- same length subject on item as on index
XSS Topic - High vulnerability :
[20190813] - Core - XSS Vulnerability
• Project: Kunena
• SubProject: Forum Core: Bbcode
• Severity: High
• Versions: 5.x through 5.1.14
• Exploit type: XSS
• Reported by: Andrey Skuratov | FBK | CyberSecurity
• Reported Date: 2019-08-13 16:04
• Fixed Date: 2019-08-13 19:00
• Release Date: 2019-08-13 19:15
• Vel url:
Description:
BBcode leads to XSS vulnerability.
26/09/2019 16:47 #45398 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.9.12).
Joomla 3.9.12 is now available. This is a security fix release for the 3.x series of Joomla which addresses one security vulnerability and contains over 30 bug fixes and improvements.
What's in 3.9.12?
Joomla 3.9.12 includes one security vulnerability fix and several bugs and improvements, including:
- Low Priority - Core - XSS in logo parameter of default templates (affecting Joomla 3.0.0 through 3.9.11)
- Fix for minyear and maxyear in the calendar
- Handle Google Font weights and styles in Protostar
- Fix user session on mssql server
- Protect SQL servers by adding pause mechanism to cli finder indexer
- Fix Imagelist custom field default image
31/10/2019 20:17 #45540 από Fotis_KFOR
Αναβαθμίστηκε το φόρουμ στην νεότερη έκδοσή του (Kunena 5.1.15), καθώς και κάποια προγράμματα του site.
The Kunena team is proud to announce the arrival of Kunena 5.1.15 [K5.1.15] which is now available for download as a native Joomla extension for Joomla 3.9.x. This version addresses most of the issues that were discovered in K 5.1 and issues discovered during the development stages of K 5.1.15.
We have Released K5.1.15 who has some improvements and fixes.
The key distinctions of K 5.1.15 are:
- Activation pending accounts are being deleted
- Remove Google+ from js social share
- Social Share icons are not displayed
- Spoiler does not render the code
- use cookieless youtube
08/11/2019 11:50 - 08/11/2019 11:51 #45551 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.9.13).
Joomla 3.9.13 is now available. This is a security fix release for the 3.x series of Joomla which addresses two security vulnerabilities and contains over 15 bug fixes and improvements.
What's in 3.9.13?
Joomla 3.9.13 includes two security vulnerability fixes and several bugs and improvements, including:
- Low Priority - Core - CSRF in com_template overrides view (affecting Joomla 3.2.0 through 3.9.12)
- Low Priority - Core - Path Disclosure in phpuft8 mapping files (affecting Joomla 3.6.0 through 3.9.12)
- Improve PHP 7.4 compatibility
- Improve reverse proxy support
- Fix active category detection
- Fix message filtering
- Improve sending mass mail
20/12/2019 10:43 #45769 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.9.14).
Joomla 3.9.14 is now available. This is a security fix release for the 3.x series of Joomla which addresses two security vulnerabilities and contains over 35 bug fixes and improvements.
What's in 3.9.14?
Joomla 3.9.14 includes two security vulnerability fixes and several bugs and improvements, including:
- Low Priority - Core - Path Disclosure in framework files (affecting Joomla 3.8.0 through 3.9.13)
- Low Priority - Core - Various SQL injections through configuration parameters (affecting Joomla 2.5.0 through 3.9.13)
- Fix incorrect id generated for input fields in repetable subform
- Fix Sample Data Learn
- Allow JSON Document caching
- Avoid errors when Joomla! gets outdated
29/01/2020 11:32 - 29/01/2020 11:33 #45885 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.9.15), όπως επίσης προστέθηκε και ένα ακόμα πρόγραμμα για κάποιες λειτουργίες / βελτίωση του site.
Joomla 3.9.15 is now available. This is a security release for the 3.x series of Joomla which addresses three low security vulnerabilities and contains over 20 bug fixes and improvements.
What's in 3.9.15?
Joomla 3.9.15 includes three security vulnerability fixes and addresses several bugs, including:
- Low Priority - Core - CSRF in batch actions (affecting Joomla 3.0.0 through 3.9.14)
- Low Priority - Core - CSRF com_templates LESS compiler (affecting Joomla 3.0.0 through 3.9.14)
- Low Priority - Core - XSS in com_actionlogs (affecting Joomla 3.9.0 through 3.9.14)
- Beez Template: Fix the consent field modal
- Action Log emails: Use of absolute URLs
- TinyMCE fixes: #27498 #27519
- User email addresses: Case insensitive management
- Prevent library extensions to overwrite core files
11/03/2020 02:31 #45985 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.9.16).
Joomla 3.9.16 is now available. This is a security release for the 3.x series of Joomla which addresses six security vulnerabilities and contains over 20 bug fixes and improvements.
What's in 3.9.16?
Joomla 3.9.16 includes 6 security vulnerability fixes and addresses several bugs, including:
- Low Priority - Core - SQL injection in Featured Articles menu parameters (affecting Joomla 1.7.0 through 3.9.15)
- Low Priority - Core - CSRF in com_templates image actions (affecting Joomla 3.2.0 through 3.9.15)
- Low Priority - Core - XSS in Protostar and Beez3 (affecting Joomla 3.0.0 through 3.9.15)
- Low Priority - Core - Incorrect Access Control in com_templates (affecting Joomla 2.5.0 through 3.9.15)
- Low Priority - Core - Identifier collisions in com_users (affecting Joomla 3.0.0 through 3.9.15)
- Low Priority - Core - Incorrect Access Control in com_fields SQL field (affecting Joomla 3.7.0 through 3.9.15)
- Link rel attributes: ‘noopener’ attributes #28005, ‘sponsored’ and ‘ugc’ attributes
- Fields - Imagelist: Correct the display of the folder structure
- Popular Tags Module fix
- User - Contact Creator plugin: catid fixed
21/03/2020 04:08 #46020 από Fotis_KFOR
Αναβαθμίστηκε το φόρουμ στην νεότερη έκδοσή του (Kunena 5.1.16).
The Kunena team is proud to announce the arrival of Kunena 5.1.16 [K5.1.16] which is now available for download as a native Joomla extension for Joomla 3.9.x. This version addresses most of the issues that were discovered in K 5.1 and issues discovered during the development stages of K 5.1.16.
We have Released K5.1.16 who has some improvements and fixes.
The key distinctions of K 5.1.16 are:
- Add unique indices to category template id tags
- PHP error: 'invalid argument for foreach() in bbcode.php line 409"
- Thumbnails should be hidden, missing in crypsisb3
- Thumbs should be hidden, when images are in messages
- Mail subscription sending delay to after response
- Allow to install on J!3.10 and remove J!4.0
- Attachment reference is not being deleted
- !kunena:jot cache - drop message from app.input after render complete
- Log shows not all actions
- Undefined variable: category index page
- Can't save profile when Signatures = No
- JSON-LD error on BreadcrumbList when email in subject
- SEO: Duplicate title on additional pages
- Error on social share icon Linkedin
- Categories disappears in the backend when is set Read Only Mode
- SEO: Subcategory is noindex, nofollow when use global
- Let users edit the subject has different effects depending on the use
- fix php 7.4 nbbc
- Protect Attachments breaks PDFs in messages
- Got error 'PHP message: PHP Notice: Undefined variable: config
- Add authorise on message helper
- The topic layout Threaded breaks the pagination
- rejects sanitize for access to user->timestamp, since forum/avatar
- fix jssocial
Χρόνος δημιουργίας σελίδας: 0.381 δευτερόλεπτα
