Διάφορες εργασίες / αλλαγές στο site
14/04/2021 19:10 #47361 από Fotis_KFOR
Απαντήθηκε από Fotis_KFOR στο θέμα Διάφορες εργασίες / αλλαγές στο site
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.9.26).
Joomla 3.9.26 is now available. This is a security release for the 3.x series of Joomla which addresses 2 security vulnerabilities and contains more than 30 bug fixes and improvements.
What's in 3.9.26?
Joomla 3.9.26 includes 2 security vulnerability fixes and addresses several bugs, including :
Security Issues Fixed :
- Low Severity - Low Impact - Escape xss in logo parameter error pages (affecting Joomla! 3.0.0 through 3.9.25)
- Low Severity - Low Impact - Inadequate filters on module layout settings (affecting Joomla! 3.0.0 through 3.9.25)
Bug fixes and Improvements :
- Fix caching issues after rebuilding update sites
- Allow to configure load balancer/reverse proxy setting
- Fix loosing extra query parameter for update sites
- MySQL and MariaDB compatibility fixes
- Fix frontend create article permission
- Update CodeMirror to 5.60.0
- Addional PHP 8 improvment
27/05/2021 00:34 #47448 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.9.27).
Joomla 3.9.27 is now available. This is a security release for the 3.x series of Joomla which addresses 3 security vulnerabilities and contains more than 15 bug fixes and improvements.
What's in 3.9.27?
Joomla 3.9.27 includes 3 security vulnerability fixes and addresses several bugs, including :
- Low Severity - Low Impact - Adding HTML to the executable block list of MediaHelper::canUpload (affecting Joomla! 3.0.0 through 3.9.26)
- Low Severity - Low Impact - CSRF in AJAX reordering endpoint (affecting Joomla! 3.0.0 through 3.9.26)
- Low Severity - Low Impact - CSRF in data download endpoints (affecting Joomla! 3.0.0 through 3.9.26)
- Disable FLoC by default
- Postgres compatibility fixes for smart search
- Allow objects stored in tables as json
- Improve indexing performance of Smart Search
03/06/2021 10:26 - 03/06/2021 10:28 #47462 από Fotis_KFOR
Αναβαθμίστηκε το φόρουμ στην νεότερη έκδοσή του (Kunena 5.2.5).
The Kunena team is thrilled to announce the final release of Kunena 5.2.5, a native Joomla extension for Joomla 3.9. This version addresses most of the issues that were discovered in K 5.2 and issues discovered during the last development stages.
Main changes in K5.2.5 :
Fixed :
- Can't add an attachment to the message when Add Suffix to URL and rewrite url is enabled
- Workaround on CKeditor to avoid to it fails completly when the start or end tag aren't terminated like : Hello world![/ b
- Editing removes the subscription (Part 4)
- Exact forum post link is missing in search results
- Kunena Discuss Error: Rendering Error in layout Topic/Item when topic layout is Threaded or Indented
- Poll: Notice: Undefined variable: polllifespan - (if the Lifetime field is not filled)
- In backend, in templates list view before to do the request to get the list of premium templates it check if the method to do it are presents in the system
- Allowing ',' in font name in bbcode
- Polls are not displayed Rendering Error in layout ...
- Ban from forum does not work (part 2)
- Don't logout the user when do unban, related to the issue
- When the poll has ended display a different string next to the poll life span
- Quote on messages done on previous versions not show the author user of the quote but the current user
- On crypsisb3 and crypsisb4, the poll icon is disabled on categories which have polls enabled which contains sub-categories
- On crypsisb3 and crypsisb4 when edit a poll the fields (poll title, options...) aren't filled
- On crypsisb3 and crypsisb4 some strings of poll dialog aren't here and the poll title label isn't translated
- Impossible to choose birthdate with datepicker
- An username still appears on quote even on quote not related to a message
- When quote a message from someone which have a name or an username with more than one word, it displays only the first word
- When try to enabling some integration plugins it doesn't work
- We need another message when someone try to enable not needed Kunena plugins
Added :
- Display poll end time if exist next to the poll title on results and vote layout
Changed :
- Update CKeditor to 4.16.1
- Set a bit smaller the poll life time
- Set the following date format for all datepicker : yyyy-mm-dd
07/07/2021 20:25 #47532 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.9.28).
Joomla 3.9.28 is now available. This is a security release for the 3.x series of Joomla which addresses 5 security vulnerabilities and contains 15 bug fixes and improvements.
What's in 3.9.28?
Joomla 3.9.28 includes 5 security vulnerability fixes and addresses several bugs, including :
- Low Severity - Low Impact - XSS in JForm Rules field (affecting Joomla! 3.0.0 through 3.9.27)
- Low Severity - Low Impact - DoS through usergroup table manipulation (affecting Joomla! 2.5.0 through 3.9.27)
- Low Severity - Moderate Impact - Lack of enforced session termination (affecting Joomla! 2.5.0 through 3.9.27)
- Low Severity - High Impact - Privilege escalation through com_installer (affecting Joomla! 2.5.0 through 3.9.27)
- Low Severity - Moderate Impact - XSS in com_media imagelist (affecting Joomla! 3.0.0 through 3.9.27)
- Update CA certificates
- Smart Search: Fix inserting tokens to DB
- Fix search suggestions for mixed-case searches
28/07/2021 09:26 #47600 από Fotis_KFOR
Αναβαθμίστηκε το φόρουμ στην νεότερη έκδοσή του (Kunena 5.2.6).
The Kunena team is thrilled to announce the final release of Kunena 5.2.6, a native Joomla extension for Joomla 3.9. This version addresses most of the issues that were discovered in K 5.2 and issues discovered during the last development stages.
Main changes in K5.2.6 :
Fixed :
- Crypsisb3 & Crypsisb4 : The BBcode editor loads no toolbar (crypsisb4 missing style to diplay bbcode correctly)
- Wysiwyg : You can't Submit the message
- Wysiwyg: Remove attachment from message, duplicates the code tags (fix install all)
- Quick Reply and go to editor - only the CKEditor receives the content
- BBcode and Wysiwyg etitor: Remove single images from messages do not work correctly
- Typo in administrator en-GB.com_kunena.views.ini line 922
- Insert images in messages works only with the CKEditor
- Crypsisb3 & Crypsisb4 : The BBcode editor loads no toolbar (missing images in crypsisb4)
- Only with Crypsisb3 & Crypsisb4: It does not switch to another editor
- Temporary rendering error at editor
- Only with PHP 8 : Warning at bullet list
- Only with PHP 8 : Warning: getimagesize - when protect attachment is on (apply the fix too in crypsisb3)
- Only with PHP 8 : Warning: Undefined array key at quoted text
- [CKEditor] CKEditor bug using lists
- Error when trying to view profile of banned user
Added :
- Reintroduce the editors available in Kunena 5.1.x to let users replace CKeditor
Changed :
- Disable the WYSIBB option in template settings untill that last bug with it are fixed
30/08/2021 11:31 #47627 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.10.1).
Joomla 3.10.1 are now available. These are bug-fix releases for the 3.10.x series of Joomla which contain many bug fixes and improvements.
What's in 3.10.1?
Joomla 3.10.1 addresses several bugs, including :
- Make sure the Joomla Update is not pointing to Joomla 4 while it shows the Default Update Server
- Remove unused fields so they do not cause javascript errors during pre-update check
- Backport: Add folder permissions check for com_joomlaupdate
14/09/2021 23:23 #47672 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.10.2).
Joomla 4.0.3  and 3.10.2 are now available. These are bug-fix releases for the 4.0.x and 3.10.x series of Joomla which contain many bug fixes and improvements.
What's in 3.10.2 ?
Joomla 3.10.2 addresses several bugs, including :
- Improve texts that are shown when there is a standalone update for the Joomla Update Component
- Improvements for the pre upgrade checker
28/10/2021 00:27 #47724 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.10.3).
Joomla 4.0.4  and 3.10.3 are now available. These are bug-fix releases for the 4.0.x and 3.10.x series of Joomla which contain many bug fixes and improvements.
What's in 3.10.3?
Joomla 3.10.3 addresses several bugs, including :
- Fix an calendar error with IE11
- Update the cacert file
- Improve the loading of tags on the contacts component
05/12/2021 12:36 #47802 από Fotis_KFOR
Αναβαθμίστηκε το φόρουμ στην νεότερη έκδοσή του (Kunena 5.2.7).
The Kunena team is thrilled to announce the final release of Kunena 5.2.7, a native Joomla extension for Joomla 3.9. This version addresses most of the issues that were discovered in K 5.2 and issues discovered during the last development stages.
Main changes in K5.2.7 :
Fixed :
- Crypsisb4 want to load bootstrap 2 instead of svg
- Missing language string for BS4 setting in CrypsisB4 template
- Crypsisb4 : in quick reply with modal and always visible options anonymous box and subscribed are in the same place
- Crypsisb4 : in quick reply the anonymous box and subscribed are in the same place
- Crypsisb3 and Crypsisb4 : Revert changes about anonymous checkbox
- Revert changes about anonymous checkbox and hide sensitive informative (Part 2)
- CrypsisB4 : use B4 styling for tabs write and preview when use bbcode editor
- When enable anonymous and post as guest users logued see the anonymous box
- CrypsisB4 : when use default setting for quick reply, nothing open when click on button quick reply
 - Typo in url to get user profile link
- CrypsisB4 : when click on delete all attachments it displays a javascript error
- CKEDITOR instance is not defined in edit.js file when using bbcode editor
- Crypsisb4,Crypsisb3: Change of the category switches to legacy symbols
- Display checkbox for hide sensitive information and name for anynomous even if user is logged
- QR and go to editor - Text is not transferred to the editor #8582
- Quick Reply and go to editor - missing in crypsisb3 and crypsisb4
- Quick Reply and go to editor - it only keeps the content if you use the button at the last message on each side
- Forgot to change the files when set Joomla! minimum version to 3.10.3
- Error in javascript console about CKeditor missing plugin file because it try to load it
- Quotes show only first names, not full name
- For each link it adds int(0) int(1) at the beginning of the message
- [CKEditor] Line break shows the html code in the message
- Search user avatar, the query to the user list return some null result for "photo" item
- When bbcode tags aren't terminated you have some warning
Changed :
- Update minimum version for Joomla! to 3.10.3
- Update CKeditor to 4.17.1
- Update CKeditor to 4.16.2
- Update minimum version for Joomla! 3.10.0 and set as preferred
- Update minimum version for Joomla! 3.10 to RC1
- Update fontawesome to 5.15.4
15/12/2021 10:14 #47826 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.10.4).
Joomla 4.0.5  and 3.10.4 are now available. These are bug-fix releases for the 4.0.x and 3.10.x series of Joomla which contain many bug fixes and improvements.
What's in 3.10.4?
Joomla 3.10.4 addresses several bugs, including :
- PHP 8.1 compatibility patches
- Update cacert.pem as of: Tue Oct 26 03:12:05 2021 GMT
- Fix wrong input filter type for extension names of site and admin languages in the extensions installer
- Fix tinymce issues when resorting happens
08/01/2022 08:11 - 17/06/2022 15:06 #47883 από Fotis_KFOR
Αναβαθμίστηκε το φόρουμ στην νεότερη έκδοσή του (Kunena 5.2.8 ).
The Kunena team is thrilled to announce the final release of Kunena 5.2.8, a native Joomla extension for Joomla 3.10. This version addresses most of the issues that were discovered in K 5.2 and issues discovered during the last development stages.
Main changes in K5.2.8 :
- Profile position top or bottom shows the content vertically
- Missing to apply changes for ebay in crypsisb3 and crypsisb4
- The setting of ebay cert id wasn't saved and improve code ebay
- Change to comply ebay API changes in order to retrieve ebay item
- Fix to support bbcode tag in K5.1 and fix link to post for K5.2
- Insert All Button not put the attachments in place of cursor #7990
- When insert all is clicked prevent press enter fire the button
- Fixed icons disappearing in Kunena 5.2.7
- Wrong language string for desc crypsis b4 in backend
- Update link to ebay dev page in config panel and remove useless
- Missing file on which copyright year hasn't been edited to 2022
- Set copyright year to 2022 (Part 2)
- Missing comment on js on code which prevent press on enter key
- Change the javascript variable to com_kunena.kunena_upload_files_preload_for_edit
- On some files the date of copyright was forgot to be changed
- Renamme variable editor_type into editorType
- Set legacy url to disabled/deprecated by default,notice if enabled
- Remove deprecated state on resize() method in KunenaImage class
- Set Joomla! 3.10.4 as minimum version
19/01/2022 17:32 #47900 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.10.5).
Joomla 4.0.6 and 3.10.5 are now available. These are bug-fix releases for the 4.0.x and 3.10.x series of Joomla which contain many bug fixes and improvements.
What's in 3.10.5 ?
Joomla 3.10.5 addresses several bugs, including :
- Privacy requests and confirmation can now be made by logged-in users only
- Improve the message for the backups to specifically include the “filesystem” and the “database”
- Fix an regression with the Progressive caching to cache modules per custom menu assignment
- Update simplepie to 1.3.3
13/03/2022 08:15 #48023 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.10.6) όπως και κάποια components / extensions.
Αναμένω να βγουν συμβατές εκδόσεις των προγραμμάτων για τη νέα έκδοση Joomla 4 που κυκλοφορεί αρκετό καιρό και μόλις όλα είναι συμβατά θα γίνει αναβάθμιση στη Joomla 4.x (προβλέπω τρέξιμο / πανικό πάλι) :P
04/04/2022 20:37 - 04/04/2022 20:38 #48090 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.10.7 και 3.10.8 )
Joomla 4.1.2 & 3.10.8 is now available. This is a security release for both the 4.x and the 3.x series of Joomla which address a few security vulnerabilities and contains various bug fixes and improvements.
What’s in 3.10.8?
Joomla 3.10.8 includes all security patches from 3.10.7 except 20220303 that has been reverted due to implementation issues :
Security Issues Fixed with 3.10.7 :
- Low Severity - Moderate Impact - Zip Slip within the Tar extractor
- Low Severity - Low Impact - Path Disclosure within filesystem error messages
- Low Severity - Moderate Impact - Missing input validation within com_fields class inputs
- Low Severity - High Impact - Inadequate filtering on the selected Ids
- Low Severity - Low Impact - Inadequate validation of internal URLs
Bug fixes and Improvements with 3.10.7 :
- Backport JQuery UI security patch for CVE-2021-41184
- Disable Google Fonts setting for 3.10.7+ new installations
- Fix updating redirect values unintentionally changed
- Remove FLoC setting as it has been abandoned
- E-Mail Cloak: TLDs long as 10 will no longer truncated until
- Privacy Consent wording I agree vs I do not agree
11/05/2022 17:34 #48175 από Fotis_KFOR
Αναβαθμίστηκε το site στην τελευταία έκδοση του CMS (Joomla! 3.10.9)
Joomla 4.1.3 & 3.10.9 are now available. This is a bug fix release for both the 4.x and the 3.x series of Joomla which contains various bug fixes and improvements.
What’s in 3.10.9?
Joomla 3.10.9 includes all security patches from 3.10.7 except 20220303 that has been reverted due to implementation issues :
Bug fixes and Improvements with 3.10.9 :
- Correct date format in Last-Modified Header
- Dedicated string for "I do not agree" over the general JNO
- Update Ca cert files as of 26.04.2022
- Improve remind an PW request / reset messages
Χρόνος δημιουργίας σελίδας: 0.550 δευτερόλεπτα
